Hi Experts,
I am trying to remove Document which is attached to Part with revision 001 and attach Document with revision 000(old revision).
I have created an action on Part Document relationship.
I'm getting the old revision item id i.e Document id, after getting this ID I'm trying to create a relationship between Part and Document with below code.
var newPartDocRelItem = inn.newItem("Part Document", "add");
newPartDocRelItem.setProperty("source_id",parentPartID);
newPartDocRelItem.setProperty("sort_order", sort_order);
newPartDocRelItem.setProperty("related_id",oldItemID);
newPartDocRelItem = newPartDocRelItem.apply();
But, above code will add the same item i.e item with revision 000
I have also tried this code
newPartDocRelItem.setProperty("source_id", parentPartID);
newDocItem = inn.newItem("Document", "get");
newDocItem.setProperty("id", oldItem);
newPartDocRelItem.setRelatedItem(newDocItem);
Still I'm not able to add the relationship with previous revision, Document with 001 revision gets added
