As per title
How can I catch onSaveCommand "End" event. So when the items have been successfully saved.
Thank you for your help!
As per title
Did you try using an onAfterUpdate event? Or is this one not sufficient?
havent tested that since i couldnt find any documentation regarding this. Am I missing documentation? I will go try this right now and report back
p.s. can you tell me what "object" i can attach this to? I'm working on javascript side
found the solution
Cool that you were able to find a solution! I didn´t know the registerCommandEventHandler.
The onAfterUpdate event I suggested is a server event that you can add in your ItemType. An Update is normally triggered when a user changes and saves something, so it can be used as some kind as onSaveCommand.
If your are a subscriber, there is additional documentation available that show a lot of examples about the various events. But you do not necessarily need it. I worked without it 3 years. You can also take a look at the programmers guide, this one is free available.
Angela can you tell me where the additional documentation is available? We are subscribers.
Thank you for all the help
Just take a look into the training folder in the FTP.
I guess i wasnt informed by my colleagues:)
Thank you Angela
Oh I know this situation. I worked 3 years without the dev guide as I just didn´t know that it exists.
But hey, this way I worked myself through quite every line of code in Innovator. Also it made me cry as I discovered that stuff I solved with 20 lines of code can also be solved with one...
20 lines are ok:) few hundred not so hehe
