Hello
as per title - how can we set the filter for search dialog in javascript
Hello
For this use case, we typically recommend creating a new property on the ItemType to serve as a placeholder to attach your onSearchDialog event to. This will new property is typically not intended…
It is possible to filter a search dialog by setting an onSearchDialog event on a property of an ItemType as outlined in this blog.
When calling a search dialog from JavaScript like in your example…
When calling a search dialog from JavaScript like in your example, you can set the sourceItemTypeName and sourcePropertyName in the parameters you pass in. If an onSearchDialog event exists on the property name you pass in using these parameters, that filter will be applied to the search dialog opened by your code. For a full list of the parameters available when opening a search dialog, please see this blog post on using standard aras dialogs.
Hello Christopher, I've met with this article before but i was rather certain it involved custom search dialog, maybe im wrong? I will read this article thoroughly in hopes of understanding it and come back with more questions probably. Thank you for now.
Hello again Christopher, my code is below could you help me understand what i could bind the onSearchDialog event to? Dialog itself contains just a promise and dom element of dialog. And i tried to connect to the event on the node itself (but it obviously doesnt emit it)
For this use case, we typically recommend creating a new property on the ItemType to serve as a placeholder to attach your onSearchDialog event to. This will new property is typically not intended to store any data and should be hidden from every form and grid. You can call this property something like filter_placeholder.
Once you have this new property on the Part ItemType, you can attach your onSearchDialog to it and update your method code to use this new property's name to call the filtering event.
not behind my computer but im assuming onSearchDialog is one of the aras events and not a javascript dialog events?
That's correct. It's an event that you can set specifically on Property items.
Thank you Christopher
Once I'm in the method initiated by the OnSearchDialog event, how do I get properties from the item on the form/grid that initiated the search?
For example, I want to mimic the "Pick/Replace" action in a Part BOM, but I need to set a filter using a prefix based on a property on the part in the Part BOM grid that the action was called on.
I can't seem to find a way to access properties from any context items. All I can see is that I'm searching for a particular item type.
-Ken
Hello Christopher, I have a scenario now where I am trying to do something similar but have one additional condition :).
Via an Action / Dialog in a first step I am asking the user for a target lifecycle state. Based on that selection, I need to present a search dialog as described above, but somehow I need to pass the selected lifecycle state on to the search dialog so that it can be obtained from within the OnSearchDialog method.
I have the search dialog opening already such that the OnSearchDialog method is triggered but all additional non-standard passed parameters seem to be discarded.
for example:
var param = {
targetLCStateNew = "<someID>"
Any suggestions on how to pass some information on to the search dialog so that it has some *context* for the OnSearchDialog method when opened from a JS method?
Copyright © 2020 Aras Open PLM Community | Privacy Policy
