Dear all,
I would like to create some item types by AML code, I have already the code, but I can't find the option in Aras Innovator to implement my code? I need to instal another program?
Thank you very much in advance.
Dear all,
Hi John,
If you're attempting to execute some AML code against an innovator instance, you should navigate to http://(yourInnovator)/(yourWebAlias)/client/scripts/nash.aspx
The nash script allows you to execute AML against your database.
AJ
you may need to use http://serverURL/webAlias/Client/scripts/nash.aspx?username=username for new versions of ARAS Innovator - replace the values in bold with your own values.
