This script has the error message when I vote in the workflow: Not a single item
I just want the script can determine if the [classification] column not filled by user, and it can show message "Please key classification!"
Could anyone help me please? Thank you very much.
Item itemQ = inn.newItem("MI_ISSUE_TODOLIST","get");
itemQ.setAttribute("select","classification");
itemQ.setProperty("id",itemQ.getID());
itemQ = itemQ.apply();
string OwnID2=itemQ.getProperty("classification");
if (OwnID2 == "")
return inn.newError("Please key classification!");
return this;
Hello annieshih,
It looks like the issue with the code you provided is on line 4. You cannot use itemQ.getId() to set the id because you have used itemQ.apply to get any results yet.
Andrew Johnson
Software Engineer for Aras Labs
