Hi Expert,
Would you help me understand in which case 'Change Pending' in a Part is set?
In editing mode (state of a part is Preliminary), I can't untick it.
Thank you.
the Changes Pending checkbox cannot be set by the user. The checkbox is set when the corresponding Item is used in a Change Process.
These two Methods do the job:
PE_clean_has_change_pending_prop
PE_update_has_change_pending
With "Where Used" you can see, that these Methods are used in ItemType Server Events. But beware - that´s only half the truth. Most of the time, these Methods are triggered by LifeCycle transistions.
These two Methdos trigger the checkbox update quite often:
PE_OnChangeItemReleased
PE_ChangeItemTransition
When you create a custom change process, you must extend these two with your own functions.
