I followed Programmer's Guide.pdf (10.1: .NET IOM) to make a simple login to ARAS .
But I keep getting this error message, can anyone help me?
Thanks!
Thanks!
there is nothing obviously wrong with your code. Programmers guide 10.0 is already a bit dated. Do you really still work on Innovator 10? There is a newer guide available, also the sample code probably equals your current used one
But do you use correct version of IOM.dll that matches your current Innovator version?
Sorry,I didn’t mention that i am going to login Aras12 and IOM is 12 version.
the 12.Programmer’s Guide.pdf’s index is belong to 10.1:IOM
Ah, I mixed the numbers of the chapter in the guide with the Innovator version.
I don´t know what causes you error. But one thing in your code is unusual. In your isError() block you convert the result Item to a string. Not sure if this causes your error message. But to get the error text, you normally use "getErrorDetail()" or "getErrorString()"
Something like this
Item login_result = conn.Login();
if (login_result.isError())
MessageBox.Show("Error during login: " + login_result.getErrorDetail());
This is working well here with the same code and a URL like this:
https://XXXX/1Z62/Server/InnovatorServer.aspx
Take care of the IOM.dll library used too.
