How can I update expired Aras certificates
E:\Aras\OAuthServer\App_Data\Certificates
the certificate under this directory are expired how can i update this?
OMG, thanks for this hint! Haven´t noticed yet that the certificates can expire.
Unfortunately I don´t know how to create new certificates. I know that installing Innovator creates a new set of certificates. In worst case reinstall Innovator and relink your database.
But I assume that there must be a better solution. Maybe we can create our own with openssl or similar??
--> https://stackoverflow.com/questions/10175812/how-to-generate-a-self-signed-ssl-certificate-using-openssl
Can you describe the effects of the invalid certificates? I assume not all features of Innovator will work anymore? (ConversionServer? Vault?)
I have moved my own instances from Windows Server 2012 to 2022 a few weeks ago, so I am right now not affected. But I would be interested in a solution too! I wonder why we haven´t heard anything from Aras regarding this issue. I guess many Innovator 12 installation are more or less 2 years old and can face this trap soon.
Hi Haider and Hkhan,
were you able to find a solution for this one?
I need to find a solution...till 2024. So there is no real hurry. But I think this topic will become relevant for many users who don´t update on a regular basis. So it´s better to be prepared.
I haven´t done any tests regarding custom certificates yet. And so far I haven´t seen any document related to certificates in https://www.aras.com/support/documentation/ . Not sure if Aras is aware of the issue.
IMPORTANT: For anyone who came across this post by accident: If you use the same Innovator 12+ instance for around 2 years, check the validity of your certificates. You might be affected by the topic of this post too.
Hope this posts gets more attention.
Thanks again for bringing up the topic!
Hello Angelalp,
I contacted Aras for help and the following is the solution they provided
To generate new certificates:
CreateOAuthCertificates.bat <ServerName> <Password>
Where:
ServerName – the name of the server for which a certificate should be generated (OAuthServer, InnovatorServer, VaultServer, AgentService, SelfServiceReporting).
Password – the password for the private certificate.
Note: Each run of the batch file generates a pair of certificates in the {Current_Directory}\Output\ directory, for example: OAuthServer.cer (public certificate) and OAuthServer.pfx (private certificate protected by the password). You will need to run this for each part of the application components.
Once the Certificates have been created copy them the corresponding directories.
Deploying the OAuthServer Certificates:
Deploying the Aras Innovator Server Certificates
Deploying the Vault Server Certificates:
Deploying the Agent Service Certificates
Deploying the Self Service Reporting Certificates:
Specify password in oauth\client\secret\certificate\@password attribute of SelfServiceReporting\OAuth.config file.GenerateOAuthCertificates (1).zip
Hi Hkhan,
many thanks for sharing this information! I made a quick test and the resulting certs lock fine.
I am a little bit proud that my earlier openssl idea wasn´t so wrong at all. It´s exactly the same concept that Aras uses.
Best wishes!
Copyright © 2022 Aras Open PLM Community | Privacy Policy
