Item fileObj1 = inn.newItem("File", "add");
fileObj1.setProperty("filename", "filename1.txt");
fileObj1.attachPhysicalFile(filepath1);
fileObj1 = fileObj1.apply();
if (fileObj1.isError())
return inn.newError("Error in fileObj1 " + fileObj1.getErrorDetail());
// Delete temporary File from Server
FileInfo fileInfo = new FileInfo(filepath1);
fileInfo.Delete();
Item fileObj2 = inn.newItem("File", "add");
fileObj2.setProperty("filename", "filename2.txt");
fileObj2.attachPhysicalFile(filepath2);
fileObj2 = fileObj2.apply();
if (fileObj2.isError())
return inn.newError("Error in fileObj2 " + fileObj2.getErrorDetail());
string filepath1 = @“C:\Aras\filename1.txt”;
string filepath2 = @“C:\Aras\filename2.txt”;
In terms of uploading multiple files, is there a particular reason you are creating File items directly like this? Typically, I would expect these files to be related to a Document or another ItemType. If you relate these Files to an item instead, you can upload multiple files using the sample below.
Item doc = inn.newItem("Document", "add");
doc.setProperty("item_number", "My doc");
//First file
Item docFile = doc.createRelationship("Document File", "add");
docFile.setFileProperty("related_id", filepath1);
// Second file
Item docFile2 = doc.createRelationship("Document File", "add");
docFile2.setFileProperty("related_id", filepath2);
// Apply
return doc.apply();
If you need to upload these as File items without containers, I would recommend using the CheckinManager class which was built for this kind of use case. You can see an example of using this class below.
Item fileUpload = inn.newItem("tmp");
// File 1
Item file1 = inn.newItem("File", "add");
file1.setProperty("filename", "filename1.txt");
file1.setProperty("actual_filename", filepath1);
file1.setProperty("checkedout_path", @"C:\Aras");
Item located = file1.createRelationship("Located", "add");
located.setProperty("related_id", "67BBB9204FE84A8981ED8313049BA06C"); // default vault
fileUpload.appendItem(file1);
// File 2
Item file2 = inn.newItem("File", "add");
file2.setProperty("filename", "filename2.txt");
file2.setProperty("actual_filename", filepath2);
file2.setProperty("checkedout_path", @"C:\Aras");
Item located2 = file2.createRelationship("Located", "add");
located2.setProperty("related_id", "67BBB9204FE84A8981ED8313049BA06C"); // default vault
fileUpload.appendItem(file2);
// Apply
fileUpload.removeItem(fileUpload.getItemByIndex(0));
IomFactory factory = new IomFactory();
Aras.IOME.CheckinManager cm = factory.CreateCheckinManager(fileUpload);
return cm.Checkin(1);
Looking to adapt this for uploading from 20 to 1000 files as we migrate from the older PLM Systems to Aras
Examples I've seen require "related_id" leading me to believe this would be a two-step process.
Batch load document information, pull "related_id" and then build .cs to upload physical file (.pdf)
Does Aras facilitate the multi-file upload/migration? Is there an admin tool to address this?
Copyright © 2022 Aras Open PLM Community | Privacy Policy
