Ad Workflow Process Path to Started Workflow
Good day all.  Does anyone know how to add a path between two Activities when a workflow has already been started?  I have a few changes that had Override Path selected, but no way to return to the previous Activity.  Any help would be appreciated.  Thank you
  • Hi Nathan,
    your request is already a few days old, but maybe you´re still interested in some hints.
    In general modifying started Workflows is not indented by Innovator.
    If you need to do it as admin to fix a few affected Workflows, you can try to manipulate the Activity relationships in the running Workflow Process. Not a pretty solution, but your best chance.
  • Angela,
    Good day.  I have been out of the office for the last week.  Do you know how I can add a path from one activity to another in a Workflow Process that has already been started?  We had a snafu with one of the in-house changes and I want to send it back, but don't have an option for it.  Thanks.
  • Do you need to add an Activity or just a Path? Adding an Activity in a running Workflow is super hard. Better start a new process.
    If you just need a path, you could try to add one in your Workflow-map --> Activity --> select your activity --> Paths.
    The "Path" tabs shows, in which direction there are pathes from the activity. Change there will not necessarily show up in the map, but maybe it will work.
  • I need to add a path between two existing Activities in a workflow that has already been started.
  • I finally figured out the solution to my problem with this.  First I do a Nash search with the following AML, using the change number for the Workflow Process name.
    <AML>
    <Item type='Workflow Process' action='get' select='keyed_name'>
      <name></name>
      <Relationships>
        <Item type='Workflow Process Activity' action='get' select='related_id'>
          <related_id>
          <Item type='Activity' action='get' select='name,keyed_name,id'>
          </related_id>
      </Relationships>
    </AML>
    Once I get the IDs for the activities that I want the path to go between, I use this AML to create the path.
    • related_id = GOING TO activity ID
    • source_id = COMING FROM activity ID
    • permission_id = Activity
    <AML>
    <Item type='Workflow Process Path' action='add'>
      <permission_id>46245093DDBE45109FEFBD5A4703AF2F</permission_id>
      <sort_order>0</sort_order>
      <related_id></related_id>
      <source_id></source_id>
      <name></name>
    </AML>
