Good day all. Does anyone know where I have to go to change the default Font Family? Currently it is set to tahoma, arial, helvetica, sans-serif. I would like to remove tahoma or move it to the back of the list. Thank you.
Hi Nathan,
oh I cannot count how often i replaced 'Tahoma' manually with a more up-to-date font. In Innovator 12 Aras itself finally had mercy and at least removed it by default.
You should be able do this customization in the FormTool/fieldTools.html in the codetree.
Angela,
I tried this, but it didn't seem to work. I reordered the fonts so Tahoma was at the end, but it didn't seem to take. Not sure if I did something wrong.
Innovator > Client > scripts >FormTool > fieldTools.html
Did you clear your cache?
Dag-nabit! I knew it had to be something that I did, or didn't do in this case. Thanks again for all of your help.
