From the Server side API, how do I get the connection string (i.e. Server, SQL Database)? I need it to execute custom SQL code that joins data from another database.
From the Client Side, I can use
var url = aras.getServerBaseURL();
var base = aras.getBaseURL();
But these functions are not available from the Sever Side API
I feel I am on the right right track with
dim scb as object = inn.getConnection
dim oInnDatabase as object = scb.CCO.DB.InnDatabase '.databaseName
dim fooDatabaseServerName as object = oInnDatabase.DatabaseServerName 'Works: Gives SBIWS457
Examining the properties in Visual Studio Watch, I found the exact place I want to be, but am unable to access the properties
olnnDatabase.ActiveInteractor.CurrentConnection.ConnectionString '(Failes)
This seems like it should be simple, but I can't seem to find any reference to functions that call back to the initiating server from the Server Side API.
Kent
