update a part's extended property through the iom
hello,
i have been able to update the extended property of a part through aml but i'm looking fo a sample code to understand how to do it with iom(innovator object model)
thanks,
Lucas
  • Hi Lucas
    Can you give a try using below code (Replace bold letters in below code)
    Innovator innovator = this.getInnovator();
    Item partEdit = innovator.newItem("Part", "edit");
    partEdit.setAttribute("id", "4F353307B92C40B5A9AADE4B1C857CDQ"); // Change with Part Item ID
    partEdit.setPropertyAttribute("xp-cost", "set", "value"); // Update the XProperty you want to update
    partEdit.setProperty("xp-cost", "100"); // Update the XProperty and its value
    partEdit = partEdit.apply();
    return partEdit;
    Thank You
    Gopikrishnan R
  • thank you very much,
    I am also having trouble getting an xproperty value from an item. i have an id of an item and want to get the value of some of its xproperties
    i've tried with getitembyID followed by a getproperty/getpropertyAttribute(Name of my x Property)
    but without success if you also have a sample code for that or where to look for it would really help.
    Lucas
  • Hi Lucas
    xProperties cannot be accessed similar to other properties in item. You need to run below query and then access the xProperties
    Item partGet = innovator.newItem("Part", "get");
    partGet.setAttribute("id", "4F353307B92C40B5A9AADE4B1C857CDQ"); // Change with Part Item ID
    partGet.setAttribute("select", "xp-*"); //change to specific xProperty
    partGet = partGet.apply();
    string xProp = partGet.getProperty("xp-cost")
    return partGet;
    Gopikrishnan R
  • hello
    thanks it is working well.
    i have a last question related to this topic, how do you create a new part with Xproperties programatically?
    Lucas.
