Is there a way to use javascript, in Email Notification Body HTML field? So that, multiple item details can be rendered and populated in the email.
Thanks in Advance
Thanks in Advance
Script in Email? Do you want to hack somebody? :) . Javascript in Email is not supported in modern Email readers.
But I assume that was not your question. I assume you want to render a custom email Body? Not at your client PC, but inside your Innovator at the moment the email is send?
Look at this community project: https://github.com/ArasLabs/email-related-files
It shows how to send emails via Method with custom body. Note that the project is a little bit dated, the code doesn´t use the latest functions to send email. But you should be able to google them easily. As far as I remember, even the Innovator Method editor recommends you the correct replacement
