If method execution time is more then timeout exception will occur it in that case method catch block will execute or not?
Regard,
Suhas
Regard,
Suhas
Hi Suhas,
there is a timeout exception class available So yes, a timeout can trigger a catch block. But it may not work for all use cases.
When I remember right, the WebClient class has no timeout property, so in this case it wouldn´t work and you have to google a workaround.
I tried many times but still can't find a solution on google bubble shooter
Copyright © 2022 Aras Open PLM Community | Privacy Policy
