I have a blob from the clipboard. Basically It is an image. I put the blob data in an img tag.
So I wanna upload the blob data to the vault and use it as an Image property.
Is there any idea to upload blob to vault in javascript?
Not directly your questions, but it contains file upload samples:
community.aras.com/.../how-to-add-restrictions-to-aras-vault-selectfile-file-picker
Thank you. I solved the problem thanks to you.
I made a html component in form like below.
When copy and paste an image from clipboard, it will be uploaded in vault.
and the uploaded file will be Item's image property.
<div>
<img src="" id="pastedImage">
</div>
<script>
document.onpaste = function(event) {
var items = event.clipboardData.items;
console.log(JSON.stringify(items)); // will give you the mime types
var blob = items[0].getAsFile();
var reader = new FileReader();
reader.onload = function(event) {
console.log(event.target.result);
document.querySelector('#pastedImage').src = event.target.result;
var file = new File([blob],'test.png',{type:"image/png"});
var newFile = aras.newFileItem(file);
var fileId = newFile.getAttribute("id");
var fileItem = aras.IomInnovator.newItem();
fileItem.loadAML(newFile.xml);
fileItem = fileItem.apply();
window.handleItemChange("_paste_image","vault:///?fileId="+fileId);
}; // data url
reader.readAsDataURL(blob);
</script>
