Hi Sanu,
I'm a ARAS newbie and I copy the code from your post and I used the new CCO.SystemEventLogger.CreateSystemLogRecord because the CCO.Utilities.CreateSystemLogRecord is deprecated now.
I assume it write a line when a user logon in "System Event Log", but I don't find any log line. What's wrong in my assumption?
Thank you for help.
//Store Last Successful Login Name
Item itm = this.newItem("Variable", "edit");
itm.setAttribute("where", "[variable].name='LastLogin'");
itm.setProperty("value", eventData.LoginName);
itm.apply();
//Create System Events Log
//CCO.Utilities.CreateSystemLogRecord("SuccessfulLogin", "onSuccessfulLogon", eventData.LoginName, "Login Successful");
CCO.SystemEventLogger.CreateSystemLogRecord("SuccessfulLogin", "onSuccessfulLogon", eventData.LoginName, "Login Successful");
return this;
Do you have a System Events Log Descriptor for your Event Type? If not, please create.
The Log Level setting of the System Events Log Descriptor must be >= than the value in the Variable SystemEventLogLevel.
Good luck - if you still read this
On another note as well you need to make sure that you have permissions to update the variable. In our instance it would not work for non admin users.
