Hello ALL,
I have an itemType (itemTypeOne) with 2 properties (propertyOne and propertyTwo) and one relationship that has 2 properties :
relationPropertyOne (datasource =itemTypeTwo) and relationPropertyTwo (datasource =stringValue)
What i want to do is create an item of itemTypeOne with relationship.
below is the code that i have developped without success :
const string url = "url of the instance";
const string db = "db-name";
const string user = "userName";
const string password = "password";
var httpServerConnection = IomFactory.CreateHttpServerConnection(url, db, user, password);
var loginResult = httpServerConnection.Login();
if (loginResult.isError()) return loginResult;
var remoteInnovator = IomFactory.CreateInnovator(httpServerConnection);
var relatedItem = remoteInnovator.newItem("itemTypeOne","add");
relatedItem.setProperty("propertyOne ", "value1");
relatedItem.setProperty("propertyTwo", "value2");
Item getValue= remoteInnovator.newItem("itemTypeTwo","get");
Item valeur= getValue.getPropertyItem("relationPropertyOne");
var relationship = remoteInnovator.newItem("relationshipName", "add");
relationship.setProperty("relationPropertyOne ", "stringValue");
relationship.setPropertyItem("relationPropertyOne ",valeur);
relationship.setRelatedItem(relatedItem);
relatedItem.addRelationship(relationship);
relationship.apply();
return relatedItem.apply();
NOTE: i have attached the server method in a button in the Main Window Toolbar, and it's working fine when i test adding an item without relationship.
below the error when i click in the buuton:
Any help please ?
