Add field Last released version
I want to show the last Revision Released in the document form .
I added a text field in the form and a methode on the event onformPopulated of the form .
The code of this method is actualy :
    if (propName == "last_major_rev_released") {
        elements[i].value ="The last rev. released"
     //code to get the last revision released
So the text The last rev. released is showed in the field.
Can you help me to write  the code (javascript) to get the last revision released ?
Top Replies
  • Hi Jeromecha
    You can use below javascript method to achieve this
    var configId = document.thisItem.getProperty("config_id");
    var releasedItem = new Item('Document', 'get');
    releasedItem.setAttribute('select', 'major_rev');
    releasedItem.setProperty('config_id', configId);
    releasedItem.setProperty('is_released', '1');
    releasedItem.setProperty('is_current', '1');
    releasedItem = releasedItem.apply();
    if(releasedItem.isError())
    return;
    var allElement = document.getElementsByTagName("input");
    for (var i=0; i<allElement.length; i++)
    var property = allElement[i].name;
    if (property == "last_major_rev_released")
    allElement[i].value = releasedItem.getProperty('major_rev');
    Thank You
    Gopikrishnan R
  • Hi
    Thanks for your reply.
    Your code doesn't answer exactly my question by was very helpfull.
    The JS code to show the last major revision released is :
    //aras.AlertSuccess (document.thisItem.getProperty("item_number"));
    releasedItem.setProperty("item_number", document.thisItem.getProperty("item_number"));
    releasedItem.setProperty("generation", "*");
    releasedItem.setPropertyCondition("generation", "like");
    releasedItem.setAttribute("orderBy", "generation desc");
    //aras.AlertSuccess("nb" + releasedItem.getItemCount());
    last_rev="";
    if (releasedItem.getItemCount() > 0) {
    item =releasedItem.getItemByIndex(0);
    last_rev = item.getProperty("major_rev");
    else {
    last_rev="";
  • Glad to hear that my answer provided some inputs to you.
