I used the sample below from an HTML Field on a form to pull the item_numbers from the Part BOM relationship and displayed them in the main form.Looks like you forgot to include your code to your post :p, could you post this example's code so i can see how you did it. Léo
showRelatedItems = function() {
var part = document.thisItem;
var relationships = aras.getRelationships(part.node, "Part BOM");
var container = document.getElementById("relatedItemContainer");
for (var i = 0; i < relationships.length; i++)
var relItem = aras.getRelatedItem(relationships[i]);
var relItemNum = aras.getItemProperty(relItem, "item_number");
var newDiv = document.createElement("div");
newDiv.setAttribute("class", "related_item");
newDiv.innerHTML = relItemNum;
container.appendChild(newDiv);
window.addEventListener("load", showRelatedItems);
</script>
<div id="relatedItemContainer"></div>
