fill in a filtered list dynamically
Hello ALL,
I have two list and i want them to be filled dynamically by a method, the first is a normal list and the second is a filtered list.
I have already managed to fill in the first automatically by a client method.
The values of the first list are: A, B, C, since the second list is a filtered list which depends on the first list Then:
If the first list contains A the second filtered list will contain the value 1
If B => 2
If C => 3
below the code I used from a forum with the event onLoad:
var dropdown = getFieldComponentByName('listeOne');
var teams = aras.IomInnovator.newItem("ItemType", "get");
teams.setAttribute("select", "id, keyed_name");
teams = teams.apply();
listOfTeams = [{
label: '',
value: ''
for (var i = 0, teamCount = teams.getItemCount(); i < teamCount; i++)
var team = teams.getItemByIndex(i);
listOfTeams.push({
label: team.getProperty("keyed_name"),
value: team.getProperty("id")
dropdown.component.setState({list: listOfTeams});
So i want to filter the second list (1,2,3) based on the values in the firsll list (A,B,C)
Is there any way please to dynamically fill in the second filtered list  ?
  • Hello ALL
    Can anyone help on how to achieve this please ?
  • Hi Mouad
    Can you try the below steps and let me know if it works
    Step 1: Navigate to Administration --> List
    Step 2: Create new list
    Step 3: Navigate to Filter Value
    Step 4: Fill your list values
    Example:
    Step 5: Create New JavaScript Method and copy below code
    var UpdateListValuesAPI = function() {
    var dropdown = getFieldComponentByName('listeone');
    var listOfTeams = [];
    for (var i = 0; i < teams.getItemCount(); ++i)
    listOfTeams.push({
    label: team.getProperty('keyed_name'),
    value: team.getProperty('keyed_name')
    list: listOfTeams,
    calculatedWidth: '',
    value: listOfTeams[0].value
    UpdateListValuesAPI.prototype.updateSecondList = function() {
    var selectListValue = document.querySelector("input[name='listeone']").value;
    var dropdown2 = getFieldComponentByName('listetwo');
    var values = aras.IomInnovator.newItem("Filter Value", "get");
    values.setAttribute("select", "label,value");
    values.setProperty("filter", selectListValue);
    values.setProperty("source_id", "38EEFD3D9AB749478495D437D9919D7D"); // TO BE REPLACED
    values = values.apply();
    if (values.isError())
    aras.AlertError(values.getErrorString());
    return;
    else
    var listTwo = [];
    for (var i = 0; i < values.getItemCount(); ++i)
    var listVal = values.getItemByIndex(i);
    listTwo.push({
    label: listVal.getProperty('label'),
    value: listVal.getProperty('value')
    dropdown2.component.setState({
    list: listTwo,
    value: listTwo[0].value
    objUpdateListValuesAPI = new UpdateListValuesAPI();
    Step 6: Replace Source_ID with ID of the above created list
    Step 7: Open Form where your need to use this (example Part Form)
    Step 8: Ensure that form has the listeone and listetwo fields
    Step 8: Add above method in Form Event --> On Load
    Step 9: Create New JavaScript Method and copy below code
    objUpdateListValuesAPI.updateSecondList();
    Step 10: Add this method in field listetwo --> Field Event --> On Focus
    Step 11: Unlock form and test the data
    Thank You
    Gopikrishnan R
