Possible to update source_id? Aras Version 11.0 SP14
I would like to change a record's "source_id" value using a command like:
<Item type="myType" action="edit" id="F54D10BECFC14EAA88D09048A6EFCA1E">
<source_id>07DD8562F5FB43E7BC04DD152268B002</source_id>
Does Aras forbid any "source_id" editing in Aras Version 11.0 SP14?  I get no error but I also get no change when I run this command.
Thank you
  • This is the result that I get.  As you can see, the "source_id" does not have the correct value.
    <SOAP-ENV:Envelope xmlns:SOAP-ENV="">schemas.xmlsoap.org/.../">
      <SOAP-ENV:Body>
        <Result>
          <Item type="myType" typeId="A13838068E8D4452A2382569B6024F34" id="F54D10BECFC14EAA88D09048A6EFCA1E">
            <_notes>Hey TEST</_notes>
            <behavior>float</behavior>
            <config_id keyed_name="F54D10BECFC14EAA88D09048A6EFCA1E" type="myType">F54D10BECFC14EAA88D09048A6EFCA1E</config_id>
            <created_by_id keyed_name="Innovator Admin" type="User">30B991F927274FA3829655F50C99472E</created_by_id>
            <created_on>2020-05-13T06:53:08</created_on>
            <generation>1</generation>
            <id keyed_name="F54D10BECFC14EAA88D09048A6EFCA1E" type="myType">F54D10BECFC14EAA88D09048A6EFCA1E</id>
            <is_current>1</is_current>
            <is_released>0</is_released>
            <keyed_name>F54D10BECFC14EAA88D09048A6EFCA1E</keyed_name>
            <major_rev>A</major_rev>
            <modified_by_id keyed_name="Innovator Admin" type="User">30B991F927274FA3829655F50C99472E</modified_by_id>
            <modified_on>2020-05-13T07:47:21</modified_on>
            <new_version>1</new_version>
            <not_lockable>0</not_lockable>
            <permission_id keyed_name="myPermission" type="Permission">86112AB4833F4AE584DC50FF266FB120</permission_id>
            <sort_order>128</sort_order>
            <source_id keyed_name="myName OLD" type="myParentType">CC8319DB41A5429EB1EF46C5166ABDC0</source_id>
        </Result>
        <Message>
          <event name="ids_modified" value="F54D10BECFC14EAA88D09048A6EFCA1E" />
        </Message>
      </SOAP-ENV:Body>
    </SOAP-ENV:Envelope>
