I have created a workflow map and lifecycle map and linked them together as well as linking them to an item type. Lifecycle map is working fine but workflow map is not working. What could be the possible reason?
Can you expand on what you mean by "workflow map is not working" for me? Is this the ItemIsLockedException you've mentioned in a couple of other posts, or a different, specific issue? If you could explain the steps you take, starting from looking at the workflow map, that lead to the error it would help me look into this.
Skyler C.
Copyright © 2020 Aras Open PLM Community | Privacy Policy
