"effective_date" check error is missing of the part in the Express ECO?
オフライン
Hi Aras Community,
I am running a standard Express ECO Workflow for a single Part file. However, Aras pops up this error when the part without proper "Effective Date" assigned. How can I get rid of this check/modify if I don't want it?
"The value of the effective_date property specified for the Part is invalid. A value is required and it must be greater than or equal to the today date"
Thank you all!
  • Some questions first:
    - What is kind of change do you do in your Impact Matrix?
    - What action do you use? (Release, Version, etc.)
    - When the change affects a Part, what is the parts current state and what shall be the target state?
    - Where are you in your Workflow? What is your current Activity and what is your target Activity?
    The Method PE_ChangeItemTransition contains a couple of validation function, but I am not sure if this one is included in the standard test set.
  • オフライン in reply to AngelaIp
    Thank you Angelalp. I found the issue was coming from my Part Form. The data source of Effective Data is BLANK. This caused the ECO can't pass.
