Set "Item has BOM"-indicator
To indicate that a Part has BOM or not I want to set a field (HasBOM) to 1 or 0
I have below server side code  triggered on onBeforeAdd and  OnBeforeUpdate on the Part item type
It works,
But I have to press save twice!? to have the field updated after I removed or added a BOM,
is there a way to have it updated directly on save???
Thanks for any idea
//Mikael
// Method to check if item has BOM and set HasBOM "
string issueID = this.getProperty("source_id","");
Item updatedBOM = inn.applyAML( "<AML>" + " <Item type='Part BOM' action='get' select='related(item_number)'>" + " <source_id>" + this.getID() + "</source_id>" + " <related_id>" + " <Item>" + " </Item>" + " </related_id>" + " </Item>" + "</AML>");
if (updatedBOM.getItemCount() > 0)
this.setProperty("hasbom", "1");
else
this.setProperty("hasbom", "0");
return this;
  • Hi Mikael
    My guess is, your method code updatedBOM.getItemCount() returns '0' count on OnBeforeAdd event and return '1' OnBeforeUpdate event. (when you press second time, it is onBeforeUpdate event). Instead of updating the hasbom field on each time part is updated or added, you can implementing on Part BOM item type (instead of Part) onbeforeAdd (update hasbom to 1) and onbeforeDelete (if count of Part BOM is 0, then update hasbom to '0'). or you can use onInsertRow and onDeleteRow events on Part BOM relationship type
    Currently, I trying to implement this in my local environment, if I'm able to finish, I will update code here.
    Thank You
    Gopikrishnan R
  • Hi Mikael,
    please check out the Files flag used in Manufacturer Parts. It does something similar and works very reliable. The corresponding Methods can be found as Server Events in ItemType Manufacturer Part Files. But you have to change the corresponding SQL Procedure.
  • Hi Angela, thanks
    I tried it and modified the code
    But requires that you only have one relationship-name named:  "Part"
    I had for ItemType Part, two relationships ("Part BOM" and "Part Alternate") both with name "Part"
    When I removed the Alternates Tab, then it worked
    So how could I keep the Part Alternates-relationship and have the code to work?
    My SQL (based on SQL "update_has_files_flag")
    create procedure HasBOMFlag(@itemtypename nvarchar(32),@itemID char(32))
    AS
    BEGIN
    DECLARE @relationship_db_name nvarchar(32)
    DECLARE @itemtype_db_name nvarchar(32)
    SET @itemtype_db_name = (select instance_data from [ITEMTYPE] where name = @itemtypename)
    SET @relationship_db_name = (select instance_data from [ITEMTYPE] where
    id = (select relationship_id from [RELATIONSHIPTYPE] where
    source_id = (select id from [ITEMTYPE] where name = @itemtypename)
    AND
    related_id = (select id from [ITEMTYPE] where name = 'Part')))
    DECLARE @SQLstr nvarchar(500)
    DECLARE @ParmDefinition nvarchar(500);
    SET @ParmDefinition = N'@id char(32)';
    DECLARE @count int
    SET @SQLstr = N'UPDATE [' + @itemtype_db_name + ']
    SET hasbom = CASE
    WHEN (select count(id) FROM [' + @relationship_db_name + '] where SOURCE_ID = @id) > 0
    THEN ''1''
    ELSE ''0''
    END
    WHERE ID=@id';
    EXECUTE sp_executesql @SQLstr, @ParmDefinition, @id=@itemID
    SET @SQLstr = N'SELECT * FROM [' + @itemtype_db_name + '] WHERE ID = @id'
    END
  • Hi,
    I had the same problem :-).
    Just keep it simple:
    AND
    name = 'Part BOM'))
    As long as you don´t feel the need to change the name of the Part BOM ItemType, you will be fine.
