Dynamic workflow, set assigned id based on drop down list
I am new with C#
I am trying to read an ECO form drop down list value (manufsites) and then based on that add corresponding identity as assigned.
I can without the IF statement set the identities as assigned,
but when try to read my drop down list value it does not work,
any ideas, please help
my code:
// Called OnActivate from activities in the Simple Change workflow. Adds assignments to
// the activity based on the Owner or Manager of affected items
string actId = this.getID();
// Retrieve the workflow item
Item wflItem = this.newItem("Workflow","get");
wflItem.setAttribute("select","source_id,source_type");
Item wflProc = wflItem.createRelatedItem("Workflow Process","get");
wflProc.setAttribute("select","name");
Item wflProcAct = wflProc.createRelationship("Workflow Process Activity","get");
wflProcAct.setAttribute("select","related_id");
wflProcAct.setProperty("related_id",this.getID());
wflItem = wflItem.apply();
if (wflItem.getItemCount() != 1 ||
wflItem.getProperty("source_id","").Length != 32 ||
wflItem.getPropertyAttribute("source_type","keyed_name","").Length < 1)
return inn.newError("Error retrieving workflow: "+wflItem.getErrorDetail());
Item q = this.newItem();
q.loadAML("<Item type='Activity Assignment' action='get' select='id'><source_id>"+this.getAttribute("id")+"</source_id></Item>");
q = q.apply();
if (q.getItemCount()>0) return this;//The activity is reactivated.
bool permissionWasSet = false;
Aras.Server.Security.Identity transIdentity = Aras.Server.Security.Identity.GetByName("Aras PLM");
try
permissionWasSet = Aras.Server.Security.Permissions.GrantIdentity(transIdentity);
//GET the manufsite from the manufs drop down list ------------
string ManufSit = wflItem.getProperty("manufsites");
if (ManufSit== "aaaa")
//IF I remove the IF row above, then below Identity is set correctly (note fictive values in this example)
string identId = "xxxxxxxxxxxx";
Item assignment = this.newItem("Activity Assignment", "");
assignment.setAction("add");
assignment.setProperty("source_id", actId);
assignment.setPropertyAttribute("locked_by_id","is_null","1");
assignment.setProperty("related_id",identId);
assignment.setProperty("voting_weight", "50");
assignment.setProperty("is_required", "1");
assignment = assignment.apply();
if (assignment.getItemCount() != 1) return inn.newError("Error creating assignment: "+assignment.getErrorDetail());
if (ManufSit== "bbbb")
string identId = "yyyyyyyyyyy";
finally
if (permissionWasSet)
Aras.Server.Security.Permissions.RevokeIdentity(transIdentity);
return this;
