Dynamic workflow, set assigned id based on drop down list
I am new with C#
I am trying to read an ECO form drop down list value (manufsites) and then based on that add corresponding identity as assigned.
I can without the IF statement set the identities as assigned,
but when try to read my drop down list value it does not work,
any ideas, please help
my code:
// Called OnActivate from activities in the Simple Change workflow. Adds assignments to
// the activity based on the Owner or Manager of affected items
string actId = this.getID();
// Retrieve the workflow item
Item wflItem = this.newItem("Workflow","get");
wflItem.setAttribute("select","source_id,source_type");
Item wflProc = wflItem.createRelatedItem("Workflow Process","get");
wflProc.setAttribute("select","name");
Item wflProcAct = wflProc.createRelationship("Workflow Process Activity","get");
wflProcAct.setAttribute("select","related_id");
wflProcAct.setProperty("related_id",this.getID());
wflItem = wflItem.apply();
if (wflItem.getItemCount() != 1 ||
wflItem.getProperty("source_id","").Length != 32 ||
wflItem.getPropertyAttribute("source_type","keyed_name","").Length < 1)
return inn.newError("Error retrieving workflow: "+wflItem.getErrorDetail());
Item q = this.newItem();
q.loadAML("<Item type='Activity Assignment' action='get' select='id'><source_id>"+this.getAttribute("id")+"</source_id></Item>");
q = q.apply();
if (q.getItemCount()>0) return this;//The activity is reactivated.
bool permissionWasSet = false;
Aras.Server.Security.Identity transIdentity = Aras.Server.Security.Identity.GetByName("Aras PLM");
try
permissionWasSet = Aras.Server.Security.Permissions.GrantIdentity(transIdentity);
//GET the manufsite from the manufs drop down list ------------
string ManufSit = wflItem.getProperty("manufsites");
if (ManufSit== "aaaa")
//IF I remove the IF row above, then below Identity is set correctly (note fictive values in this example)
string identId = "xxxxxxxxxxxx";
Item assignment = this.newItem("Activity Assignment", "");
assignment.setAction("add");
assignment.setProperty("source_id", actId);
assignment.setPropertyAttribute("locked_by_id","is_null","1");
assignment.setProperty("related_id",identId);
assignment.setProperty("voting_weight", "50");
assignment.setProperty("is_required", "1");
assignment = assignment.apply();
if (assignment.getItemCount() != 1) return inn.newError("Error creating assignment: "+assignment.getErrorDetail());
if (ManufSit== "bbbb")
string identId = "yyyyyyyyyyy";
finally
if (permissionWasSet)
Aras.Server.Security.Permissions.RevokeIdentity(transIdentity);
return this;
  • Dropdowns depend on your Innovator version. This one is based on SP15:
    var itemTypeDropdownComponent = getFieldComponentByName("mydropdownlist");
    // var listlength = itemTypeDropdownComponent.component.state.list.length;
    // Get selected value from dropdown list
    var selectedValue = "";
    if(itemTypeDropdownComponent.getValue() !== "")
    selectedValue = itemTypeDropdownComponent.getValue();
    window.handleItemChange("my_identity", selectedValue);
    Please note: In this sample, the drop down is based on a list, that uses ids as values, and text as labels. If your drop down just contains blank text as values, you will have to transform these to the necessary ids for the identities for yourself.
  • Hi
    Are you able to get these value "ManufSit" or is it empty ? Try below code and let me know if you still face issues
    q = q.apply();
    Item ecoParent = this.newItem("Simple ECO", "get");
    ecoParent.setID(wflItem.getProperty("source_id"));
    ecoParent.setAttribute("select","manufsites");
    ecoParent=ecoParent.apply();
    try
    string ManufSit = ecoParent.getProperty("manufsites");
    finally
    return this;
  • Thanks Gopikrishnan, it worked perfectly!!
    Do you know if it is possible by method to remove/reset the assigned identity?
    Let's say user selected wrong in the drop down list, and AA was set instead of BB
    Then in next step user AA rejects it and we then want to change AA to BB
    But when looking in the flow, AA is still set
    So is it possible to reset next assigned ID before code above executes, so  thew new choice BB gets assigned in next step?
    thanks//Mikael
  • Hi Mikael
    Try below code and let me know if it helps. Include bold text in your method.
    q = q.apply();
    try
    Item getAssignment = this.newItem("Activity Assignment", "get");
    getAssignment.setProperty("source_id", actId);
    getAssignment.setAttribute("select", "id");
    getAssignment = getAssignment.apply();
    if(!getAssignment.isError())
    for (int i = 0; i < getAssignment.getItemCount(); i++)
    var assignmentId = getAssignment.getItemByIndex(i).getID();
    Item removeAssignment = this.newItem("Activity Assignment", "delete");
    removeAssignment.setAttribute("id", assignmentId);
    removeAssignment.setAttribute("doGetItem", "0");
    removeAssignment = removeAssignment.apply();
    if(removeAssignment.isError())
    return inn.newError("Error removing assignment: "+removeAssignment.getErrorDetail());
    finally
    return this;
    Thank You
    Gopikrishnan R
  • Hi, no it did not work
    I selected "AA" and AA was assigned when I sent it to activity "Review" (= correct)
    AA then rejected ECO and then I unlocked it, changed AA to BB in the form, then sent it to Review again and AA was still set as assigned.
    //Mikael
  • Hi
    Can you confirm where this method is attached in workflow?. Also can you share the workflow screenshot
  • I quickly tested and it seems to be working in my local instance. Can you confirm the identity id hard coded in method xxxxx and yyyyyy are different?
    Also if only one assignment is there, then I guess voting weight should be 100 instead of 50 in your method
  • yes the id's are different
    string identId = "32456085EDC34925930C2B5559ACEEB4";
    string identId = "0D2D86D4654B4304965A74572373791E";
    I also tried hard code one of the assigned id's in the remove string
    removeAssignment.setAttribute("id", "0D2D86D4654B4304965A74572373791E");
    but did not work either, the id was still assigned in the Review stage
    Regarding voting weight, I just updated the method to set weight correctly
    One selected = 100
    Two selected = 50 each
  • could it be Permission related?
    Even if I login as admin, root, ... any ID..
    I can't change/ delete assigned in the workflow, the icons are greyed out
