Error: Method "CE_LinkManufacturer" failed
Hello, Dear
<Version 12.0 Build 13341>
Regarding add maker information, cannot add data of "CE Manufacturer name "
Detected Error:  Method "CE_LinkManufacturer" failed.
technical message aras_object "undefined ": "Not a single item
I suspect SQL database table have something issue.
And I cannot find table  for CE_LinkManufacturer.
Though I imported Aras component Engineering "12.0R1", No failure was occurred at that time.
Would you please let me know any suggestion?
Sincerely
  • Hi,
    have you looked at the  'Linking Manufacturers' chapter in the CE User Guide?
    Just to be sure:
    - Are you able to add regular Manufacturer items at all? E.g. when you create a new Manufacturer and add the name by your self, can you save this item?
    - Can you do a regular search for CE Parts in Cloud Manufacturer Parts? If this one already makes trouble, you may have some general connection problem with CE.
    I really recommend you to write an email to Aras support. They are quite good in CE troubleshooting!
  • Hi ,
    I overlooked some point in the CE user guide.
    My new findings from your advice as below:
    I had read the CE user guide chapter 3 (Open Edition (Level 1) user guide.
    1.For our system, we cannot open Cloud Manufacturer Part Search.
    →Exactly, I cannot see search box as user CE user guide Figure 38.
    So  We "may have some general connection problem with CE"
    2.I tried to add part by "Manufacture Parts".
    →I can save  the parts information except "Manufacturer name".
    3.Tried to modify  Manufacturer Part
    Detected error as below
    <SOAP-ENV:Envelope xmlns:SOAP-ENV="">schemas.xmlsoap.org/.../"><SOAP-ENV:Body><SOAP-ENV:Fault xmlns:af="">www.aras.com/.../faultcode><faultstring><![CDATA[Line number 56, Error Number: CS0234, The type or namespace name 'CE' does not exist in the namespace 'Aras' (are you missing an assembly reference?)
    ]]></faultstring><detail><af:legacy_detail><![CDATA[Line number 56, Error Number: CS0234, The type or namespace name 'CE' does not exist in the namespace 'Aras' (are you missing an assembly reference?)
    ]]></af:legacy_detail><af:exception message="Line number 56, Error Number: CS0234, The type or namespace name 'CE' does not exist in the namespace 'Aras' (are you missing an assembly reference?)&#13;&#10;" type="System.ApplicationException"/></detail></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope>
    As you recommend, I'll try to understand ARAS innovator well and ask ARAS support this case.
    Best Regards!
  • Did you solved this problem, I have the same problem
  • Hi
    Regarding this failure for our case, we're using ARAS without subscription components.
    For my understanding, Utilize of CE_LinkManufacturer is needed subscription which is for Manufacturer database.
    I'm verifying original setting without any other package.
