Update Part Document Relationship
I'm trying to update PART DOCUMENT relationship but facing issue:
AML:
<AML>
   <Item type="Part Document" action="edit" where="[Part_Document].id='C080331098D24F00B635418D823D97AC'">
    <related_id>AFF14CBFFD074494B00E3D247D8D11FE</related_id>
</AML>
getting Object reference not set to an instance of an object error.
how to edit this relationship as I want to attach different document on some condition.
Maddy.
  • Hi Maddy
    Consider the below scenarios
    Part 1 ---------> Document1
    Part 2 ---------> Document 1
    Scenario 1: If you want to replace Document 1 with Document 2 in both Part 1 and Part 2, use below AML query
    <AML>
    <Item action="edit" type="Part Document" where="[Part_Document].related_id='DOCUMENT1_ID'" version="0">
    <related_id>DOCUMENT2_ID</related_id>
    </AML>
    Scenario 2: If you want to replace Document 1 with Document 2 only in Part 1, then use below AML query
    <AML>
    <Item action="edit" type="Part Document" where="[Part_Document].source_id='PART1_ID'" version="0">
    </AML>
    You can get the ID of the Part and Document by right clicking the corresponding item and in Properties
    Thank You
    Gopikrishnan
