Delete a complete BOM (if any) using Batch Loader
I am learning how to use the batch loader to add a BOM to a specific part, but now I would like to do the opposite: I would like to come up with a script I can run with the Batch Loader that would delete a BOM regardless of how many components it has. How could I get started on this?
PMateo
  • If it is one time activity fine but if it is a regular activity you can create your own action and use it in AML
    Step 1: Create a C# method in ARAS named PartBOMDelete
    Step 2: Copy the below method
    List < string > PartIDs = new List < string > ();
    var itemNumber = this.getProperty("parent_item");
    string getWhereClause = "[Part].item_number IN ('" + itemNumber.Replace(",", "','")+ "')";
    Item partItem = inn.newItem("Part", "get");
    partItem.setAttribute("select", "id");
    partItem.setAttribute("where", getWhereClause);
    partItem = partItem.apply();
    if (!partItem.isError())
    int count = partItem.getItemCount();
    for (int i = 0; i < count; i++)
    PartIDs.Add(partItem.getItemByIndex(i).getID());
    string partIdsInfo = string.Join("','", PartIDs);
    string deleteWhereClause = "[Part_BOM].source_id IN ('" + partIdsInfo + "')";
    if (!string.IsNullOrEmpty(partIdsInfo))
    Item removeBom = inn.newItem("Part BOM", "delete");
    removeBom.setAttribute("where", deleteWhereClause);
    removeBom = removeBom.apply();
    if (removeBom.isError())
    return inn.newError(removeBom.getErrorString());
    return inn.newResult("Part BOM deleted Successfully");
    Step 3: Save and Unlock the Method
    Step 4: Run the below AML query whenever required in Innovator Admin
    <AML>
    <Item action='PartBOMDelete' type='Method'>
    <parent_item>Itemnumber1,itemnumber2,itemnumber3</parent_item>
    </AML>
    Here we have created a custom action that will delete the Part BOM based on item number. Input here is Itemnumber1,itemnumber2,itemnumber3 and you can give any number of comma separated part number and note that it will delete only in latest generation.
    Thank You
    Gobikrishnan R
  • Thank you very much, I will definitely give this a try. This may be an activity we use regularly so defining a method is a brilliant idea.
    Kind regards,
    Pmateo
