Hi Team
How to disable and enable the multi value list in ARAS
Hi Team
You can look at this blog post for some examples of how to disable the various fields in a Form.
Essentially, every field can be disabled in two steps:
var input = getFieldByName("YOUR_FIELD_NAME");
input.getElementsByTagName("INPUT_TYPE")[0].disabled = true;
The multi-value list fields use a select node as input, so you can disable the field by using input.getElementsByTagName("select")[0].disabled = true;
