where can I see the multi-level BOM weight report?
thanks,
Duygu
thanks,
Duygu
Is there a problem with your weight
Hi Duygu,
There isn't a multi-level BOM weight report in an OOTB database. However, you can look at the existing BOM Costing Report as an example of how you could build your own weight report. You could even run a Save As on the BOM Costing Report to create a copy and then change all references to the cost property to weight and all references to the cost_basis property to weight_basis.
Hi Chris,
I did what you said but I can not change the column names in the report.
thanks
Duygu
The column names are set in the Stylesheet tab of the Report item in Innovator. If you do a Ctrl+F search for Cost, you should be able to find the column names that you'll need to change.
oh I did not see that tab. thank you
Duygu
