Hi!
I have a relationship named KBGF. I've created a reverse relationship between 2 Part item types.
My question is this :
How can I see the source part and the related parts in the reverse relationship tab by changing the parameters?
‘ITName=’+itemTypeName+’&itemID=’+itemID+’&reverseITName=Part&reverseRelationshipName=Part KBGF’
thanks
It don't believe it's possible to achieve the result you're looking for only by changing the parameters you pass into the ReverseItemsGrid.
If you're Aras Innovator 11.0 SP10 or later, I would recommend checking out this blog post for an example of building a Tree Grid View that could display this information. The example in the blog post demonstrates how to build a multi-level BOM, but you can just as easily build a query that does a reverse lookup. You will just need to select Add Related Item > Using Referencing Item... instead of the example in the blog.
Hi Duygu,
While it's more difficult and involved than just creating a query definition, it is possible to create a custom ReverseItemsGrid.html. I do not have any samples to provide for this kind of modification, however.
You can find the default grid in your code tree under \Innovator\Client\Solutions\PLM\scripts\ReverseItemsGrid.html in your code tree. Rather than modifying this file directly, I'd recommend making a copy of the file to make your changes in.
