\Innovator\Client\styles\
folder. Before making any changes to the code tree, we do recommend creating a backup and storing it somewhere safe in case you need to rollback any changes you've made.
To find the exact file you need to edit, you can use your browser's developer tools (which can typically be launched by pressing F12) to inspect the element. This will tell you the file name you will need to modify as well as let you play around with the stylings on your local copy of the web page.
You can edit the column header text of the search grid by editing \Innovator\Client\styles\common.css
and changing the style of the .aras-grid-head-cell-label
class.
/Innovator/Client/styles/controls/grid.css
file like below.
.claro .dojoxGridHeader tr:first-child .dojoxGridCell {
border-top: 0px none;
// Add any stylings you want here
In the future, you can use the developer tools of your web browser (which you can launch by pressing F12 on your keyboard) to inspect any elements you want to change the style of. These tools will typically tell you both the class names as well as the file in the code tree that you need to edit in order to change the stylings.
