Essig Connectors for PLM 10.0.0 - Aras Innovator 15 Connection Error
Hello there,
I installed the Essig Connectors for PLM 10.0.0 on the Aras Innovator 15 Client machine. When I tried setting the connector on the SolidWorks 2021 I got the error "It appears that the connection with the server has been disconnected". Actually it's not true because I can ping the server and got the reply as well as I can access the Aras Server via the web browser. As per this connection issue if I run the Fiddler program, it resolved my connection issue. I don't know what Fiddler do to fix the problem or why Essig Connector for PLM would needs Fiddler to run properly. Hopefully anyone could give me some advice. Thank you very much in advance for any help.
Jakk
