I am developing a detailed BOM report using XSLT and a Method in 12sp18
Typically, the Method must accept item_number as a parameter.
So I looked at the XSLT Report Tool User Guide, and Section 8.3 describes User Input for XSLT based Report - easy...
Not
The sample given has errors in the JavaScript,
for example
var params = ...
should be var param =...
The current situation is
1. Defined Action, and are able to call the action
2. The HTML page was modified to just have item_number as an input field. The HTML is presented, as per the 8.3 example
3. After entering the item_number or , nothing else happens.
4. Using F12 in Chrome, shows that the line function callback(dialogWrapper), dialogWrapper is not defined, hence the next line of var result=dialogWrapper.result produces an error.
I don't know how to get the item_number from the HTML page, to the client method for subsequent processing and report generation
has anyone used this example from the documentation?
