When I check result in AP Server about file content, the result is readbility. The screen is XML format erorr!
But if i check result from client PC , the result is show grabled. What happened ?
I found the solution!
Why localhost see http error not the same remote client about file not error?
Cause ~\VaultServer\web.config flie
The httpErrors's errorMode default value is "DetailedLocalOnly"
When you access PLM by remote cliet, the error will be garbled!!
Change
<httpErrors>
to
<httpErrors errorMode="Detailed">
