Is there a way to set the NamespacePrefix to a tag using Api?
Hello.
I am trying to use the Aras API to put Japanese values into a property whose data type is MultilingualString.
However, in My program, we need to output the DOM manipulated by the API to an XML file.
To make sure that the output XML file will work well when used in AML, we want to add the appropriate NamespacePrefix to the tags for multi-lingual tags.
Here is an example.
What you want to output
test.xml
<AML>
    <Item>
        <i18n:label_plural xml:lang="ja" xmlns:i18n="">www.aras.com/.../i18n:label_plural>
    <Item>
</AML>
Anyone, please.
