How to get the value of relationship item type using the return value of fetchRelationships
オフライン
hi,All
'my code
'This is the code I tried to write in VB
Me.fetchRelationships("File")
Dim file as Item = Me.getRelationships("File")
Dim t_file_id as string
If file.getItemCount()>0
   Dim fileCnt as Integer=file.getItemCount()
   For x=0 To fileCnt-1
      t_file_id = file.getItemByIndex(x).getProperty("related_id")
      file1= file.getItemsByXPath("Relationships/Item[@id='"+t_file_id+" ']")
      file1.getProperty("doc_name")   ' return Not a single item
   Next
End If
'file
'The value obtained is shown below
How do I get the doc_name value?
If somebody knows and can help I would really appreciate that.
Thank you.
  • I assume your current code returns the relationship itself instead of the related item.
    Maybe you can use getPropertyItem() or getRelatedItem():
    --> t_file_id = file.getItemByIndex(x).getPropertyItem("related_id").getProperty("doc_name");
  • オフライン in reply to AngelaIp
    Hi Angelalp,
       It works, thanks a lot for your help!
       I also tried another way to write it and the result is the same.
    'my code
    'This is the code I write in VB
       Dim docName as String
    '      docName = file.getItemByIndex(x).getPropertyItem("related_id").getProperty("doc_name")
          file1 = file.getItemByIndex(x).getRelatedItem()
          docName = file1.getProperty("doc_name")
       Next
    End If
