BOM with 2 ItemTypes
The BOM of my Parts are made with  2 kind of  part :
   - Component (commercial off-the-shelf), with no version management, very simple life cycle
   - Part with versionnnig, comlex life cycle ,....
In aras the ItemType "PART BOM"  (relationShip)  links Parts to Parts.
1/ But how to add "Component" ItemType  to this relationShip  if it's possible ?
2/ How would  you manage this kind of BOM ?
Thanks !
  • Hi,
    When you input a part into ARAS, it asks for the type. If you put "Assembly" as the type then you can create a BOM. For components you wouldn't need to create a BOM. You need to create your components first then once it has been created it you can add it to the BOM or any sub assembly/ assembly.
    -Hope this helps.
  • Thanks   for your anwser.
    But Part with "Component" tye have the same behavior  than the part with "Assembly" type : versionning, same life cycle, isn't it ?
    I would like to have 2 different behaviors for Component and Part  (Assembly) And a Bom part can contains Component and Parts.
    A Other possibility is to have only the ItemType Prts and hidden the field version,....  in the form  if  type is  Component, but how the specify a other life cycle ?
  • I just found that's possible to define a view and/or a life cycle depending of the classification !! Great, I will explore this feature !!
