Both the Subscriber Portal and these community pages are under the domain community.aras.com
Well, I was in class and I said I could never login to the subscriber portal. It was suggested that I use "Reset Password", so I did.
I thought it was broken because the spinner never stopped, but I did end up getting an email with a short scrambled password in it.
I was expecting to not be able to login here, to Community, with my old credentials. But, I can. And, if I go to the Subscriber Portal at: https://community.aras.com/subscriber-portal/p/login I need to go lookup the email and use that new password.
Well, I hope I can get some community voices supporting my problem as a must-fix! Having two logins for the same domain is silly.
It wouldn't be a problem if the login credentials worked for both and it appeared seamless. Even if there were two "buckets" at the very least I could then changed my Subscriber login password to one I can remember (and has more complexity than what is sent in a "reset" email)!
