Uploading a local file to Innovator using the Batch Loader
I'm having issues uploading a local file to an instance of Innovator using the Batch Loader. I have the following XML:
    <Item type="Document File" action="add">
      <related_id>
        <Item type="File" action="add">
          <actual_filename>C:\some\file\path\@1</actual_filename>
          <filename>@1</filename>
This currently fails. I had to search to find out the <actual_filename> tag is used for the fully qualified path of the file, yet it is not present in the File Item when inspecting it through Innovator Client.
Any help with this would be appreciated.
  • I've realized now that I need to specify a relationship to a vault  and have changed the AML to the following:
          <related_id>
              <filename>@1</filename><Relationships><Item type="Located" action="add"><related_id>67BBB9204FE84A8981ED8313049BA06C</related_id></Item></Relationships> </Item>
    However now I am greeted with a "File does not exists" exception even though the file does exist at the fully qualified path specified by <actual_filename> tag
  • I am trying to do the exact same thing (in 11SP15), and getting the same Batch Loader error: 'The system cannot find the file specified.'
    I've moved the file to different locations thinking Batch Loader only had permissions to read from certain locations, but I keep getting the same error.
    I'm very interested if someone knows how to resolve this! Thanks, Paul
  • I had to add another column to my CSV file that held the full file path of the file associated with each record then used that in the AML template
    <actual_filename>@25</actual_filename> (if the full file path column is column 25)
  • <Item type="Document" action="edit" version="0" id="@1">
    <Relationships>
    <related_id>
    <actual_filename>@2</actual_filename>
    <filename>@3</filename>
    <Relationships>
    </Relationships>
    </related_id>
    </Relationships>
    I did that as well. @2 = C:\temp\filename.PNG and @3 = filename.PNG
    Still get error: The system cannot find the file specified.
  • I remember now in some other Forum thread it was suggested to split the addition of documents from the upload of files. That worked for me. I would recommend adding the Documents first, and then making the File associations. Of course to do this you will need to sufficiently narrow down the document to which you wish to associate a File. (Use of where clause can help). Perhaps use a "merge" action instead of edit? I'm also not sure if you're version might have something to do with it
  • <Item type="File" action="add">
    <Relationships>
    </Relationships>
    I tried that as well, isolating just the File add command in Batch Loader, but I kept getting the same error.
  • This is the template I used for the file upload/association to document.
    <Item type="Document" action="edit" where="[Document].item_number='@2' and [Document].frame_number='@12' and [Document].sheet_number='@9' and [Document].subsheet='@48' ">
    <Relationships>
         <related_id>
             <actual_filename>@68</actual_filename>
             <filename>@21</filename>
                <Relationships>
                </Relationships>
           </related_id>
    </Relationships>
    Notice the where clause to narrow down the document (If you have an ID even better) and the action of "edit"
  • Thanks . i tried my approach in a different aras instance and it worked. so i know the problem is not in the batch loader or aml query. i'll keep troubleshooting. thanks again.
