Adding "TP_Image" from Server side methods throws "Cannot Insert Value Null into Column" exception
Hi All,
Please help me,
I'm trying to add Technical document Graphic Item using server side code as below
Item ite=inn.newItem("tp_Image","add");
ite.setProperty("item_number","124");
ite.setProperty("name","124");
ite.setProperty("thumbnail", "vault:///?fileId=63D43D90CE604A9DB6DCAC23816ECD73");
ite=ite.apply();
return this;
When I run above method I'm getting exception as
Cannot insert the value NULL into column 'SRC', table 'InnovatorSolutions_12sp6.innovator.TP_IMAGE'; column does not allow nulls. INSERT fails.
The statement has been terminated. in SQL: INSERT INTO [TP_IMAGE] ( [CONFIG_ID],[CREATED_BY_ID],[CREATED_ON],[CURRENT_STATE],[EFFECTIVE_DATE],[GENERATION],[ID],[IS_CURRENT],[IS_RELEASED],[KEYED_NAME],[LOCKED_BY_ID],[MAJOR_REV],[MANAGED_BY_ID],[MODIFIED_BY_ID],[MODIFIED_ON],[NAME],[NEW_VERSION],[NOT_LOCKABLE],[OWNED_BY_ID],[PERMISSION_ID],[RELEASE_DATE],[SRC],[STATE],[SUPERSEDED_DATE],[TEAM_ID],[ITEM_NUMBER] ) VALUES ( @p0,@p1,@p2,@p3,@p4,@p5,@p6,@p7,@p8,@p9,@p10,@p11,@p12,@p13,@p14,@p15,@p16,@p17,@p18,@p19,@p20,@p21,@p22,@p23,@p24,@p25 )
Can anyone help me on this?. Thanks in advance
