2018-01-24 11:38:57,095 [6] INFO Aras.Tools.ArasUpdateGui.Logger Checking package started: 'C:\ProgramData\Aras\ArasUpdate\QMS\11.0.1030\package.config' 2018-01-24 11:38:57,107 [6] INFO Aras.Tools.ArasUpdateGui.Logger Checking package finished 2018-01-24 11:38:57,128 [6] INFO Aras.Tools.ArasUpdateGui.Logger Installation of the package started : 'QMS' from 'C:\ProgramData\Aras\ArasUpdate\QMS\11.0.1030' directory 2018-01-24 11:38:57,129 [6] INFO Aras.Tools.ArasUpdateGui.Logger CompatibilityPackage started 2018-01-24 11:38:57,224 [6] INFO Aras.Tools.ArasUpdateGui.Logger Checking module 'IS' compatibility. 2018-01-24 11:38:57,251 [6] INFO Aras.Tools.ArasUpdateGui.Logger LoadFile started 2018-01-24 11:38:57,251 [6] INFO Aras.Tools.ArasUpdateGui.Logger Loading File : 'C:\Program Files (x86)\Aras\Innovator\Innovator\Client\scripts\include\rev.inc'. 2018-01-24 11:38:57,252 [6] INFO Aras.Tools.ArasUpdateGui.Logger LoadFile finished 2018-01-24 11:38:57,342 [6] INFO Aras.Tools.ArasUpdateGui.Logger LoadFile started 2018-01-24 11:38:57,343 [6] INFO Aras.Tools.ArasUpdateGui.Logger Loading File : 'C:\Program Files (x86)\Aras\Innovator\Innovator\Client\scripts\include\build.inc'. 2018-01-24 11:38:57,343 [6] INFO Aras.Tools.ArasUpdateGui.Logger LoadFile finished 2018-01-24 11:38:57,434 [6] INFO Aras.Tools.ArasUpdateGui.Logger Custom started 2018-01-24 11:38:57,435 [6] INFO Aras.Tools.ArasUpdateGui.Logger Custom check the property : 'Version.Check'. The value : 'true'. 2018-01-24 11:38:57,435 [6] INFO Aras.Tools.ArasUpdateGui.Logger Custom finished 2018-01-24 11:38:57,442 [6] INFO Aras.Tools.ArasUpdateGui.Logger Checking module 'DB' compatibility. 2018-01-24 11:38:57,443 [6] INFO Aras.Tools.ArasUpdateGui.Logger Application started 2018-01-24 11:38:57,492 [6] INFO Aras.Tools.ArasUpdateGui.Logger Variable 'VersionServiceUpdate' is found in DB.The value : '0'. 2018-01-24 11:38:57,493 [6] INFO Aras.Tools.ArasUpdateGui.Logger Application finished 2018-01-24 11:38:57,493 [6] INFO Aras.Tools.ArasUpdateGui.Logger Application started 2018-01-24 11:38:57,531 [6] WARN Aras.Tools.ArasUpdateGui.Logger String[] {Variable 'Application Core' is not found in DB.} 2018-01-24 11:38:57,531 [6] INFO Aras.Tools.ArasUpdateGui.Logger Application finished 2018-01-24 11:38:57,532 [6] INFO Aras.Tools.ArasUpdateGui.Logger Application started 2018-01-24 11:38:57,574 [6] WARN Aras.Tools.ArasUpdateGui.Logger String[] {Variable 'Product Engineering' is not found in DB.} 2018-01-24 11:38:57,575 [6] INFO Aras.Tools.ArasUpdateGui.Logger Application finished 2018-01-24 11:38:57,575 [6] INFO Aras.Tools.ArasUpdateGui.Logger Application started 2018-01-24 11:38:57,616 [6] INFO Aras.Tools.ArasUpdateGui.Logger Variable 'Quality Management System' is found in DB. 2018-01-24 11:38:57,617 [6] INFO Aras.Tools.ArasUpdateGui.Logger Application finished 2018-01-24 11:38:57,617 [6] INFO Aras.Tools.ArasUpdateGui.Logger Application started 2018-01-24 11:38:57,657 [6] INFO Aras.Tools.ArasUpdateGui.Logger The innovator DB contains AML package with name : 'com.aras.innovator.cmf'. 2018-01-24 11:38:57,658 [6] INFO Aras.Tools.ArasUpdateGui.Logger Application finished 2018-01-24 11:38:57,658 [6] INFO Aras.Tools.ArasUpdateGui.Logger Application started 2018-01-24 11:38:57,697 [6] INFO Aras.Tools.ArasUpdateGui.Logger The innovator DB contains AML package with name : 'com.aras.innovator.solution.PLM'. 2018-01-24 11:38:57,698 [6] INFO Aras.Tools.ArasUpdateGui.Logger Application finished 2018-01-24 11:38:57,698 [6] INFO Aras.Tools.ArasUpdateGui.Logger InnovatorDependence started 2018-01-24 11:38:57,698 [6] INFO Aras.Tools.ArasUpdateGui.Logger Required version of Innovator : '11.0 SP9'. 2018-01-24 11:38:57,748 [6] WARN Aras.Tools.ArasUpdateGui.Logger String[] {Incompatible version of Innovator} 2018-01-24 11:38:57,749 [6] INFO Aras.Tools.ArasUpdateGui.Logger InnovatorDependence finished 2018-01-24 11:38:57,749 [6] INFO Aras.Tools.ArasUpdateGui.Logger InnovatorDependence started 2018-01-24 11:38:57,749 [6] INFO Aras.Tools.ArasUpdateGui.Logger Required version of Innovator : '11.0 SP10'. 2018-01-24 11:38:57,787 [6] WARN Aras.Tools.ArasUpdateGui.Logger String[] {Incompatible version of Innovator} 2018-01-24 11:38:57,787 [6] INFO Aras.Tools.ArasUpdateGui.Logger InnovatorDependence finished 2018-01-24 11:38:57,788 [6] INFO Aras.Tools.ArasUpdateGui.Logger InnovatorDependence started 2018-01-24 11:38:57,788 [6] INFO Aras.Tools.ArasUpdateGui.Logger Required version of Innovator : '11.0 SP11'. 2018-01-24 11:38:57,827 [6] WARN Aras.Tools.ArasUpdateGui.Logger String[] {Incompatible version of Innovator} 2018-01-24 11:38:57,828 [6] INFO Aras.Tools.ArasUpdateGui.Logger InnovatorDependence finished 2018-01-24 11:38:57,831 [6] WARN Aras.Tools.ArasUpdateGui.Logger Variable 'Application Core' is not found in DB. Variable 'Product Engineering' is not found in DB. Incompatible version of Innovator Incompatible version of Innovator Incompatible version of Innovator 2018-01-24 11:38:57,834 [6] INFO Aras.Tools.ArasUpdateGui.Logger Checking module 'DBSP11' compatibility. 2018-01-24 11:38:57,835 [6] INFO Aras.Tools.ArasUpdateGui.Logger InnovatorDependence started 2018-01-24 11:38:57,835 [6] INFO Aras.Tools.ArasUpdateGui.Logger Required version of Innovator : '11.0 SP11'. 2018-01-24 11:38:57,877 [6] WARN Aras.Tools.ArasUpdateGui.Logger String[] {Incompatible version of Innovator} 2018-01-24 11:38:57,878 [6] INFO Aras.Tools.ArasUpdateGui.Logger InnovatorDependence finished 2018-01-24 11:38:57,878 [6] INFO Aras.Tools.ArasUpdateGui.Logger Application started 2018-01-24 11:38:57,916 [6] INFO Aras.Tools.ArasUpdateGui.Logger Variable 'VersionServiceUpdate' is found in DB.The value : '0'. 2018-01-24 11:38:57,917 [6] INFO Aras.Tools.ArasUpdateGui.Logger Application finished 2018-01-24 11:38:57,920 [6] WARN Aras.Tools.ArasUpdateGui.Logger Incompatible version of Innovator 2018-01-24 11:38:57,920 [6] INFO Aras.Tools.ArasUpdateGui.Logger CompatibilityPackage finished 2018-01-24 11:38:57,921 [6] ERROR Aras.Tools.ArasUpdateGui.Logger Aras.Tools.ArasUpdateCore.Implementations.Commands.CheckCompatibilityPackageCommand: Variable 'Application Core' is not found in DB. Variable 'Product Engineering' is not found in DB. Incompatible version of Innovator Incompatible version of Innovator Incompatible version of InnovatorIncompatible version of Innovator 2018-01-24 11:38:57,921 [6] INFO Aras.Tools.ArasUpdateGui.Logger Operation 'Install' failed
