Hi everyone,
I have created a new item type.
When i try to create a instance of my new item type got an error like below
"SubstitutionStage2:Expected end of the expression, found '@'. Item[2] -->@<-- type="Activity"]/name"
How to resolve this issue?
it doesn't look good. What about other itemtypes ? are you still able to create instances of other itemtypes?
If yes, then can you send an itemtype report of your newly created one?
hi..Yoann Maingon
if i unchecked default workflow in Item Type, the i can create instance of item type. Otherwise it throw an error like "SubstitutionStage2:Expected end of the expression, found ‘@’. Item[2] –>@<– type=”Activity”]/name" and it does not initiate the workflow.
Thanks and Regards,
Sathishkumar C.
hi..Yoann Maingon
Thanks and Regards,
Sathishkumar C.
