savan - Friday, March 26, 2010 1:59 AM:
Dear
friends
I am trying to generate item type using AML by importing the AML code .but I am getting an error because of ID of item i dont know how to get id for item type even i have tried using id="{@id}" but i am getting error
so please suggest me how to generate itemtype using AML code
<AML>
<Item type="ItemType" id="{@id}" action="add">
<allow_private_permission>1</allow_private_permission>
<auto_search>0</auto_search>
<enforce_discovery>1</enforce_discovery>
<hide_where_used>0</hide_where_used>
<implementation_type>table</implementation_type>
<instance_data>Work</instance_data>
<is_dependent>0</is_dependent>
<is_relationship>0</is_relationship>
<is_versionable>0</is_versionable>
<label xml:lang="en">worked</label>
<label_plural xml:lang="en">worked</label_plural>
<manual_versioning>0</manual_versioning>
<name>Work</name>
<show_parameters_tab>1</show_parameters_tab>
<unlock_on_logout>0</unlock_on_logout>
<use_src_access>0</use_src_access>
</AML>
Regards
savan
RobMcAveney - Wednesday, March 31, 2010 11:32 AM:
Simply omit the id attribute and an id will be generated for you:
<Item type="ItemType" action="add">
The id that was auto-generated will be returned in the response.
Rob
