we would like to hide or disable the My Innovator category for all the users .. how is that possible?
Hi Selvlennox,
To accomplish this you would edit all of the ItemTypes found within the My Innovator category and remove the TOC Access for all of those Items. The TOC is dynamically populated every time it is loaded, and if there are no ItemTypes within the My Innovator category the category will not show up.
AJ
You can set the identity in TOC Access for each item type under My Innovator to Administrators from World. So that it will be visible only to Administrators and not to normal users.
thanks gkarasuser, I did that but felt like cumbersome to do for each item,Anyhow I had to do the same
Copyright © 2023 Aras Open PLM Community | Privacy Policy
