How to delete relation ship before edit
Hi guys
New a method like this
Item mainItem = this.newItem("MainItem", "get");
mainItem.setID("SysID");
mainItem = mainItem.apply();
//Add Relationship
var relItem = innovator.newItem("Detail_File","add");
relItem.setProperty("related_id","fileID_A");
mainItem.addRelationship(relItem) ;
relItem.setProperty("related_id","fileID_B");
mainItem.addRelationship(relItem);
//delete relationship
//I want to delete fileID_A Relation  (But right now not save in DB so i can't get fileID_A Sys ID to delete)
mainItem=mainItem.apply("edit");
How can I do?
  • Hello Michelle,
    You can delete the relationship from this structure before you apply the item by using mainItem.removeRelationship(relItem);. The removeRelationship function expects an argument of an Item object, so you will first need to get the item you want to delete. Presumably, you're performing some kind of check to determine when the item should be deleted, so your code could look something like this:
        Item relFiles = mainItem.getRelationships("Detail_File");
        for (int i = 0; i < relFiles.getItemCount(); i++)
            Item relFile = relFiles.getItemByIndex(i);
            // do your logic on relFile here
            // if (relFile.getProperty("XXX") != "XXX")
            mainItem.removeRelationship(relFile);
    Aras Labs Software Engineer.
