krish80 - Thursday, April 23, 2009 6:36 AM:
How to get the time difference.
Example : In a Form having Two Fields (Date Field's) Like 1. Start date 2. End date . While i process the form i click & select the start date and i didnt do any thing with End Date Field (Just Blank). Now i submit (save) the form.
After some times i reopen (Modify) the same form and i click & select the End Date field , Now i submit the form.
So the fields having the values of like below :
Start_Date : 04/23/2009 10:23:35 AM
End_Date : 04/23/2009 03:20:22 PM
How to get the duration between this Hours & wants to update this into another ItemType field. (duration_time)
Guid me how to do this in server side.......
Thanks & Regards,
Krish
SamsAn - Thursday, April 23, 2009 12:25 PM:
Use onBeforeAdd and(or) onBeforeUpdate server side event method.
C# methods portions should be like:
string neutralFormat = "yyyy-MM-ddTHH:mm:ss";
DateTime startDt = DateTime.ParseExact(this.getProperty("start_date"), neutralFormat);
DateTime endDt = DateTime.ParseExact(this.getProperty("end_date"), neutralFormat);
//..... Code to find differenece
this.setProperty("end_date", calculatedDiff);
Sean - Friday, April 24, 2009 2:24 PM:
Krish,
Here is some sample code that will get the date diff for you:
string startDtStr = this.getProperty("start_date","");
string endDtStr = this.getProperty("finish_date","");
if (startDtStr =="" || endDtStr=="")
return this;
else
DateTime startDt = DateTime.Parse(startDtStr);
DateTime endDt = DateTime.Parse(endDtStr);
if (DateTime.Compare(endDt, startDt) <= 0)
Item err = inn.newError("Your finish date must be greater than your start date!!!");
return err;
else
TimeSpan dateDiff = endDt - startDt;
int days = dateDiff.Days;
int hours = dateDiff.Hours;
int minutes = dateDiff.Minutes;
float hoursTotal = ((float)days*24) + (float)hours + ((float)minutes/60);
this.setProperty("date_diff",hoursTotal.ToString());
return this;
HTH
Sean
krish80 - Saturday, April 25, 2009 12:47 AM:
Sean Coleman,
Actullay my scenario is :
Two itemtype (2 forms). In first itemtype (form1) having some fields like serialno <sequance>, empname, dept, workstart_date, workend_date..... when the user (employee) going to feed the values, he will give his name and selecting his department & pick the workstart_date.... This time he will not select the workend_date. Now he will submit the values.
After some time he will reopen the same form and he will update his workend_date.
And some of the field values are also add to 2nd Itemtype (form2)
So when the user modify (update) the form1 then only we can get the workend_date. (But you have mention the below method for onBeforeUpdate) How the method will get the workend_date.
Now my Question is:
1. How to retrive & modify (update) the perticulare serialno,empname,workstart_date.... record in the 2nd Itemtype.
2. How to get the time difference & how to update this into 2nd itemtype field.
(pls give me sample method's also).
RK
pallavig - Tuesday, July 26, 2011 5:56 AM:
It;s working good.
Thanks.
