INNOVATOR FRAMEWORK - Workflow Activity cloned
mark_chen - Wednesday, November 9, 2016 4:56 AM:
I am using the PackageImportExportUtilities ,export the 9.3 sp0 Workflow map and import to the Aras 11 SP5.
The Workflow map like below
In Aras 11 SP5 I found when I complete task of the a2 along path(return) to a1, the Activity will cloned and add two new record (a1 and a2).
But I found some activity cannot cloned the new record in Activity, why?? and the system will show "Object reference not set to an instance of an object" error
how to fix the issue?
